Overview: This how-to is the first of (hopefully) many to come, providing instructions on how to repair common problems with the Audi 80. Some of these guides may be applicable to other models (90 / 100), although as the author does not have access to either of these, it cannot be assured. This particular how-to addresses the intermittent water temperature and fuel level gauges – a fault which arises after approximately 10 years.
Time to complete: Around 20 minutes (look at the clock in the photos!)
Tools required: A long Philips-head screwdriver, some fine sand paper (400 grit)
Instructions:
The first step is to remove the top-half of the steering column surround. To do this, remove the two screws found on the underside of the steering column surround, as shown in the picture below:
Following this, you should be able to raise the upper-half of the steering column surround (as shown in the picture below). To completely remove this piece, the rear end (i.e. the end closest to the dash cluster) should be lifted first, tilting the piece. This will allow it to clear the various controls protruding from the dash cluster. After tilting it slightly, it should be able to be pulled upwards until it’s completely free.
With the upper-half of the steering column surround removed, the next step is to remove a connector which sits in the way (indicated below). The easiest way to do this is to first remove the actual connector itself, by lifting the end closest to the steering-wheel up – it should unclip from the bracket. After this, pull the metal bracket towards the steering-wheel and it should come free.
Once the connector is out of the way, the two screws holding the dash cluster in (pictured below) can be undone.
Follow this, hold onto the rubber piece with the text “UN4†and pull towards the steering-wheel, pulling slightly upwards. The dash cluster should slowly come out.
Keep pulling until the rear of the dash cluster is free from the dash cluster surround:
At this stage, the bottom of the dash cluster can be tilted upwards, and the entire cluster can rest on the steering-column:
The connections to the water temperature and fuel level gauges are now accessible. Essentially, each gauge uses two screws for the connection, as opposed to soldered joints. The interface between the circuit board of the dash, and the washer on the screw, becomes oxidized after many years, and a bad connection results. What we want to do is unscrew each screw, one at a time, and using the fine sand paper, carefully sand the contact-points for each screw. Care must be taken to ensure only one screw is ever out at any one time, otherwise the gauge itself may become misaligned. The screws we need to work with are indicated below:
As they say, installation is the reverse of removal. When putting the dash cluster back into the dash surround, the upper-half needs to be tilted backwards (i.e. towards the front of the car) slightly, otherwise it will not go in. The fit is quite snug, so a little bit of force is required to push it back into position.
Remember to replace the metal bracket, and the connector which was removed earlier on. When replacing the upper-half of the steering column surround, it’s usually easier to put the front-end (i.e. the half closest to the steering-wheel) in first, then lower the rear half. If all goes well, the gauges should now work all the time!
Instructions:
