VAG Terminology
jnrdavo
Administrator
Staff member
AFM Air flow Meter
AFR Air Fuel Ratio
BAT not British American Tobacco, but in fact...Big Ass Turbo
Blower Supercharger
BMC CDA BDC is the company, CDA is the Carbon Dynamic Airbox. It's a replacement for the stock audi air filter and housing.
BT Big Turbo or Blue Tooth
CAI Cold Air Intake
DV Diverter valve (VW version of a BOV)
EBC Electronic Boost Controller
MAF MASS AIR FLOW SENSOR. it always fails and always causes grief- learn what it is and how to clean it and half your issues are instantly solved.
IMO In my opinion
FMIC Front Mount Intercooler
TBE Turbo Back Exhaust
REPS Replicas
VAG Volkswagen Audi Group, an obsolete name (1978-1992) of the current Volkswagen Group (Volkswagen AG), a German automaker.
Also may be used in reference to VAG-COM which is a third party Windows-based software package, produced by Ross-Tech, and used for diagnostics and adjustments of Volkswagen, Audi, SEAT and Škoda vehicles.
WOT Wide open throttle (foot to the floor)
VAG Still current useage especially in financial/corporate sphere worldwide as acroynm for Volkswagen AG. (AG being corporate label similar to our Pty Ltd)
Vag-com Still in current useage but now defunct name due to alleged trademark infringement...now known as VCDS and marketed by Ross-tech LLC
AG
Thanks 4 the info, it's nice to know these little things like VAG & AG.
Need Help with the right Connector
Hi, I drive A4 1.8T build 9/98. I wanted to buy VAG com cable but confused on ebay with all the terminology. Should i Just pay more and buy it direct from Ross tech or can i save money and try my chances on eBay? and which one would suit my car?
Thanks
Is the VAGCOM simple enough for anyone to use? I mean can you stuff up the car?
You won't stuff up anything with reading fault codes, data blocks and running procedures such as throttle body adaptation etc. Don't be tempted to change any values directly though (ie. Adaptation) unless you understand what they do. A common one to change is the Service Reminder.
from my experience (quite limited) if you read and follow all instructions from Ross-Tech, whether you have the "real" cable or not you should be right.
http://ross-tech.com/vag-com/index.html
Also of help are these stickys on other forums in addition to the Ross-Tech site.
http://forums.vwvortex.com/showthread.php?5010762-DIY-VCDS-(Vag-Com)-for-Beginners
http://www.vwwatercooled.org.au/forums/f112/official-vww-vcds-tweak-library-50749.html
It's also handy to trawl through the many many adaptations available, record them, then come back and do some research before making any changes.
I have a Ross-Tech VAGCOM in Canberra if any VAG driver needs access.
Cheers,
Andrew
Hallelujah!!
OzAudi top post in forums - Well done. Very handy when you are looking for new posts in your favourite threads and they are 100 pages long
So many acronyms!
Info is much appreciated - I was even unsure what VAG meant! Well I couldn't work out the G lol
