Thread: Anybody running LED license plate lights?
    Default Anybody running LED license plate lights?
    For 2010+ A3/S3 models,
    Spoken with poli84 in length regarding these and there are heaps of variants of SMD Festoon LED Bulbs on fleabay and also from LED websites; ranging from DIY where you solder 2W 150R metal resistors together with each bulb you install or buying a set of LED that come with DIS error cancelling canbus functions.
    Has anybody successfully installed LED number plate? if so, which option did you go about?
    *edit*
    emailed a few sellers and here are the responses:
    Eric at PYSpeed (stockist of Racing Dash) says the 2010 A3/S3 models should not throw an error code as a heat socket is now included to get rid of the error light. Has anybody tried these units and can confirm they work without throwing an error light?
    HIDconcept says there has been no reported compatibility issue on 2010 A3/S3 Blesk Festoon LED yet: http://hidconcept.com/LED-Festoon.html
    Tunerdomes says the 36mm error canceling license kit should work: http://www.tunerdomes.com/index.php?...d&productId=79
    Resistors.. been installed since whenever I took photos and installed em... in the threads somewhere :)
    Go hard or go home...
    __________________________________________________ __________________________________
    08.2009 TTS 2.0 TFSI Coupe / RED / S Tronic / LED Internal Lighting / MSS MagneRide Spring Kit / etc
    VCDS (CAN) available / My Gallery / My Garage
