Thread: Noob LED Lighting Question
    Default Noob LED Lighting Question
    Hi all,
    Apparently i have to post 5 times in this section first so i may aswell ask this here. Has anyone found LED license plate lights for the A4 B7 that do not cause on error code on the cluster? I have a red led screen and have tried ebay bulbs and then purchased a full license plate light assembly from Mars Perfromance in Clayton but still got an error as soon as i put it into gear. If i need a resistor does anybody know what type i need and where i can get it installed.
    Cheers.
    Corey
    Look on audisrs.com and do a search. You'll find lots of info on it.
    graze
    2017 Aston Martin V12 Vantage
    2011, 8T RS5, Suzuka Grey
    1965 Triumph TR4, Red
    Sold
    2007 Aston Martin V8 Vantage
    2001 B5 RS4, Black Pearl Metallic, B7 RS4 wheels with 275/30/19's, Neuspeed rear ARB, 18Z cayenne six pots, JHM short shifter
    1975 Triumph TR6, French Blue,
    2010 Mini Cooper S
    Previous 2007 B7 RS4, 2007 B7 S4, 2005 B6 Avant Quattro, 2001 B5 Avant Quattro, 2001 S3
    yep u need to install bulbs waith cumbus tecknology.basically it send a signal to ur computer saying its staderd globe even its non-standerd led.
