Results 1 to 10 of 26
Thread: Modded b5 A4 & S4 parts
    Default Modded b5 A4 & S4 parts
    I have had a small accident just front bumper and guard and am weighing up the repair bill vs stripping the car. Parts list below. If your interested pm me. Car made 220kw at the wheels with this engine.
    The set up consists of standard AEB motor and being bored and stroked to 2.0l
    The parts that were used as follows...
    VW 2.0l crank
    Scat Conrods
    JE 83.5 Custom spec pistons with true 7.5 comp ratio
    Mains Girdle
    Ferrea oversize Intake Valves
    Ferrea oversize Exhaust Valves
    Ferrea Intake Valves Springs
    Ferrea Double Exhaust Valve Springs
    Ferrea Intake and Exhaust Titanium Retainers
    Ferrea Intake and Exhaust Titanium Seat Locators
    New Valve Guides and Seals
    New Valve Lifters
    New Camshaft Chain and Tensioner
    New High Flow Oil Pump
    Eurospec Adjustable Camshaft Gear
    ARP Head Studs
    $3K
    The Garett GT 28rs Custom turbo with tial 38mm wastegate and 1 month old log manifold and down pipe $1800
    Autronic Sm2 Stand alone with Autronic CDI supplying the spark $800
    I also have a link ecu for running e85 $1500
    The fueling is initially supplied by Walbro 255 in tank pump to an External Bosch Motorsport 044 pump $200
    S4 transmission and Diff with custom Gearbox PWR Cooler powered by external electric Tilton Pump incl heavy duty clutch $2500
    Spal 14" Electric Thermo Fan
    BMC Short throw shifter
    PWR power steering cooler $200
    PWR Front mount intercooler $500
    S4 side skirts and door sills
    All coolers are all custom made by PWR to suit this car with the sizing
    Koni Lowered shocks and springs with higher load rated $400
    Whiteline Rear Swaybar with reinforced brackets $200
    Chrome Molly Rear top brace
    Genuine B6 S4 wheels will be resprayed like new $900 with decent tyres
    Porsche Brembo 4 piston front calipers with S4 disk rotors
    Braded brake lines $1k
    Location Adelaide
  2. The Following User Says Thank You to enforce For This Useful Post:
    Carpo555 (August 12th, 2018)
  3. #2
  4. The Following User Says Thank You to Khoa For This Useful Post:
    Strangelove (July 19th, 2018)
  5. #3
    Quote Originally Posted by Khoa View Post
    Already on it, buddy! Thanks for the heads up.
    Sent from my SM-G960F using Tapatalk
    Wheels
    Motor
    box
    side skirts
    sway Bar
    steering cooler
    Nov 2014
    108
    ill 100% take the whiteline sway bar and links
    Do you still have the standard piston's?
    Sent from my CPH1725 using Tapatalk
  10. #8
    Apr 2008
    Sheffield,Tasmania
    303
    Thanked: 15
    Have the wheels gone? Don't need tyres and don't want them painted. How much?
    Current - 1984 WR Ur Quattro
  11. #9
    Someone has already asked for them but I'm waiting for enough interest to strip it. Otherwise someone can take the whole car off my hands for 7k.
  12. #10
    Jul 2018
    31
    Thanked: 3
    I know there are currently 2 people ahead of me but I'd like to put myself on the waitlist for the wheels as well. Cheers!
