Page 141 of 142 FirstFirst ... 4191131139140141142 LastLast
Results 1,401 to 1,410 of 1413
Thread: 2020 RS3 owner's thread
  1. #1401
    Feb 2011
    SE Melbourne
    739
    Thanked: 84
    So finally DS1'd the whip, upgrading from Unitronic stage 2 U98. Started out with a file that Domino uses on his car but my injectors weren't liking it and were maxing out pretty quick. Which also affected the amount of boost that we could play with.
    So the tuner went with a different strategy (without having to upgrade injectors) and backed off the boost and kept under the tolerances of the stock injectors. making better power with a little less torque, but sustained torque in the midrange. Nice and smooth, without any spikes or such, which help from keeping rods getting bent. Tried a higher and lower torque file as well. I've stuck with the higher torque file for now.
    Final result between the Unitronic and the DS1. Remembering that Uni was using a beta file for DNWA engines.
    Goes to show that you really should go with a custom tune, as all cars don't behave the same, even when given the exact same map.
    2020 RS3 Sedan | Dark Red Mica | Carbon Edition | Matrix Lights | Audi Corporate
  2. The Following User Says Thank You to Joecool For This Useful Post:
    jaydece (June 19th, 2021)
  3. #1402
    Quote Originally Posted by Joecool View Post
    Yeah, they still service the car for the first 3 years. I just tell them to not flash the ECU and TCU. And make sure they don't wash the car, plus tell them any niggles that the car has like squeaky sunroof and any rattles in the car (I have one that sounds like it's coming from the door card behind me). That's about it. We'll see what happens when I pick the car up this afternoon.
    Of course, I can't claim any drivetrain related issues from here on in, due to the mods made.
    Cheers, decided to go to Richmond where I bought the car, used Brighton in the past, but no pro's or con's. By the way you guys had any issues with the washer jets all over the place, the 2016 RS3 did the same, for car worth over $100K is not good. Also in bright sunlight I get a lot of multi-color speckle from the front windscreen, ? faulty glass?
    Joe Cool how was the service at Brighton?
  4. #1403
    Feb 2011
    SE Melbourne
    739
    Thanked: 84
    Quote Originally Posted by biggles View Post
    Service at Brighton was fine. I've been using them for in-warranty servicing for my last 3 cars. Only thing I found was they wiped all my VCDS mods. I'll just have to go back in and do them again!
    As for the jets you describe, one of the first mods to do is replace them with the misting jest from the A6. Originals I got here:
    https://www.ebay.com.au/itm/17417808...53.m1438.l2649
    https://www.ebay.com.au/itm/20275554...53.m1438.l2649
    Easy 2 minute replacement.
    Can't say anything about experience with the windshield other than Audi glass is f*cking soft. All 3 of my Audis have suffered either cracked glass or chips.
  5. #1404
    Cheers.
  6. #1405
    we’re gonna need a bigger boat…. RS6 order incoming
    • 2015 RS3 Sportback Nardo (SOLD)
    • 2020 RS3 Sportback Merlin (REDUX)
  7. #1406
    Apr 2017
    Melbourne, Victoria
    751
    Thanked: 114
    Just need to endure for about 6mths or so? After that your kid will outgrow the capsule and use the normal car seat..
    MY18 RS3 Sportback | PP2 | Matrix | RSDP | Gloss Black package | Ara Blue | Opti Coat Pro+ | Tinting
  8. #1407
    5,090
    Thanked: 608
    It's when they turn on to lanky teenagers that the rs6 comes in to its own!
  9. #1408
    Default 2020 RS3 owner's thread
    Yep that’s what I’ve been told, the rear facing car seat isn’t as long
    The wife’s exclusive s5 sb finally got built after repeated delays and is on the water
    After a lot of maneuvering by my dealer I secured an rs6 build slot for end of year, and Audi finally agreed to doing an exclusive color amidst all the component and build delays, but currently the exclusive upholstery shop is closed, I believe due to German covid employee restrictions. Hoping by time I need to confirm spec it reopens
  10. The Following User Says Thank You to domino_z For This Useful Post:
    beanoyip (July 19th, 2021)
  11. #1409
    Apr 2017
    Melbourne, Victoria
    751
    Thanked: 114
    Quote Originally Posted by domino_z View Post
    Will you still be keeping the RS3 after the RS6 inbound?
  12. #1410
    Quote Originally Posted by beanoyip View Post
    Undecided atm, will work it out when rs6 finally arrives
