Results 1 to 10 of 18
Thread: Random Cable Found In Plenum
  1. Default Random Cable Found In Plenum
    Hey everyone, I was cleaning out the leaves and rubbish in the plenum of my A4 today and found this random cable just hanging down in between the heater hoses, I have never opened the terminal box before so this was like this when I bought the car. I assume it belongs on the terminal off to the left hand side as it does have a dust outline, it looks like it hasn't been connected for some time, but I am not sure what this cable actually feeds, it goes into the car through the fire wall but FIK what it's for, any insight would be appreciated. The only conclusion I have come to is possibly something that draws a considerable amount of current as the cable is quite thick.
  2. Default
    Hey everyone, I was cleaning out the leaves and rubbish in the plenum of my A4 today and found this random cable just hanging down in between the heater hoses, I have never opened the terminal box before so this was like this when I bought the car. I assume it belongs on the terminal circled in red but I am not sure what this cable actually feeds, it goes into the car through the fire wall but FIK what it's for, any insight would be appreciated. The only conclusion I have come to is possibly something that draws a considerable amount of current as the cable is quite thick.
    5,070
    Thanked: 605
    Is your car new or second hand? Night have had a aftermarket amp in it...
    No I doubt it's aftermarket anything, it doesn't have an afyermarket amp, and the car is unmolested, the way the cable is crimped and the nut on top mount it all looks factory.
    Only way to tell is trace the wire and follow where it leads through the firewall and interior panels.
    If you are the only owner of the car I would find out where it leads. But if you're not the original owner then it is well possible that it some sort of aftermarket sub, original owner could have removed it and just left the wiring which is very common.
    B7 A4 2.0TQ
    8P A3 REVO
    9,903
    Thanked: 462
    Any more details on your car (model, year etc)?
    Might be able to assist if I have the above info.
  7. Default
    Hey there, it's an A4 B8 3.0L TDI, this cable looks factory, the owner before me was not into doof doof so the after market sub is not a viable answer, and if you understand how these A4 sound systems work it not just a matter of chucking another amp in...
    Just looking at it, not sure it is factory with a captive nut on the terminal and no fusible link on the suggested connection. Sure, something was there but was it that or did this cable replace what was there. Does look like something has been removed from that position though. Where it enters the fire wall, does it have a dedicated entry or has it been threaded through with other wires. As well as tracing the cable which is the only sure way, I'd check the wiring diagrams online and see if any clues jump out.
    Nov 2004
    4,297
    Thanked: 97
    Looks like the cable sneaks back through the firewall with one of the heater hoses, and it has a completely different terminal so its aftermarket.
    A wider photo of the area would be more helpful to say further.
    | GT3076R | ViPec i88 |
  10. Default
    Ok here is a pic although it is rubbish, it shows the cable going through a factory rubber gland in between the two heater hoses.Click image for larger version.
